Author Topic: Review Olight M2R Warrior // GIF's Now added to review  (Read 519 times)
Online robo819
« on: October 12, 2017, 09:30:47 AM »
This is the Olight M2R Warrior , sent to me for reiew from Olight and NO other compensation other than keeping the light for my review.
The M2R Warrior can be found at the following links (NON Afilliated)…………
https://www.olightstore.com/olight-m2r-warrior(link is external) ….. (pre-order at the time of this review , available October 15th 2017)
or at ….. http://www.ebay.com/itm/Olight-M2R-Warrior-1500lumen-Most-Powerful-Pocke...(link is external)
The M2R warrior came in a padded mailing envelope and the Olight box inside that. When I took the Olight box from the package I found a very attractive box , with everything very clearly labeled and very well packaged as I progressed through the unpacking process. Each step of the way there are printed instructions showing / telling what needs to be done next , or what a certain part of the light does or how to use it.
Once I had everything out of the box I found the light also attractive for my personal taste. It is a tube light in a sense but yet made to be a tactical light with big output. I really like the blue bezel with the small cuts in it making for a unique design on this light. The size and the feel of the M2R are both very good in my opinion and it fits my hands well. The light does not have traditional knurling , but instead has a ribbed type pattern , with lateral lines running through that , the length of the tube and small matching lateral lines on the head and the tailcap portions.
 The M2R comes with a magnetic charger that charges the included cell , or any other cell from my understanding that will fit , through the tailcap. The cell that is included is listed as a High drain 3500mAh protected cell with 10 amp discharge and 12.6 mh. Olight however DOES RECOMMEND A PROTECTED CELL. I tried several cells in the light and all appear to function as they should. Included were LG HE4 button top , LG HG2 flat top , Efest purple high drain flat top , and a LG MJ1 button top. There is also a very nice nylon holster included with a clasp type closure instead of the normal velcro. The holster can be used on a belt , hooked onto your back pack with the built on eye and even has a separate snap closure that is made onto the belt loop portion.
 The M2R utilizes the XHP 35 emitter (HD) or dome on and this one IS a NEUTRAL WHITE (also to my liking personally), and has a constant current driver from what I can see of it. The reflector is an OP with somewhat of a hotspot and decent throw for an OP reflector in a small head light , while giving a good coverage area at the same time.
 There is also a DTP copper board the XHP 35 sits on , so added bonus there.
The M2R has a tail and a side switch both , and a “Standard” or “Tactical” mode setting. The tail switch is a “Tactical” switch for the Turbo and / or Strobe functions only. I may have these backwards but I think it is….In the STANDARD mode , with a half press , the tail switch activates Turbo only and with a full press it activates the Strobe only. No matter which mode you go to with the tail switch in standard mode though , the light goes back off when the tail switch is released.
 If you turn the light on with the side switch , no matter what mode you are in , a quick press of the tail switch will turn the light back off without having to use the side switch.
 The second mode group is the “TACTICAL” group. This setting lets you use the tail switch for either momentary on of the Turbo mode with a half press, or constant on of the Turbo mode with a full press of the tail switch, with NO strobe function.
 One odd thing I discovered when in the “Tactical” group (I think)? the Turbo mode only gives 1125 lumens instead of the 1570 lumens that the STANDARD mode gives at or after the 30 second mark and leveled off , whether using the tail switch or the side switch to go into Turbo. I think if I am not mistaken , this is the way the light (driver is designed though , if I am reading the listed specs right from the Olight site.
The M2R does have mode memory from the side switch and will go back to the last used mode when the light is turned back on. The moon mode is separate with it being activated by a long press of the side switch , but it too will be memorized if the light is turned off while in moon mode and will come back on in moon. The only mode that does not memorize is the Turbo and strobe , which are both very easily activated from the tail switch. The rest of the modes can be switched by either holding down the side switch and scrolling through , or by pressing the side switch for about 1/2 second and releasing when the next mode pops up. This includes if you are starting at the moon mode and scrolling up from there. A quick click of the side switch turns the light off from any mode. Turbo can be accessed from the tail switch or a quick double click of the side switch either way and the strobe can be activated from the side switch with a quick 3 clicks , or the tactical tail switch function. When in Turbo mode there is a 3 minute step down but , the light can be bumped back up into the Turbo mode once it steps down. I would highly recommend checking how hot the light is before going back into the Turbo mode though , as it does start getting pretty hot if it is warm with little or no airflow over the light. From what I understand there IS a THERMAL SENSOR in the light , so if it is too hot you may not be able to step back up instantly.
One thing everyone should be glad to hear is…….. The tailcap DOES NOT short with a key , a coin or even a piece of 20 awg Turnigy wire pressed against the outer ring and the switch button at the same time. This means Olight addressed the problem that was present in the H2R headlamp that some were complaining about , and NO chance of shorting out of the M2R because of the magnetic tail charging system.
 I am sure it is how they set up the inside of this light though with the double tube design. By this I mean there is actually a tube inside the outer tube that can carry the current instead of the single tube design carrying the current as we are used to seeing , it flows through the separate tube making it possible to separate the outer and inner portions on the tailcap and the light tube both..
Some may not like the “Tactical” only tail switch , but for those of us who know how handy it can be in certain situations , it is a great thing to have. I was a prison guard for 14 years and a Peace officer (LEO) for 12 years and I would have loved to have a light with the Tactical only tailswitch during any or all of those years to be honest , but that is again my personal preference and yours may vary.
 Any way it goes , I personally think this will become one of my top 5 lights of preference with the USB magnetic charger for when I am in a vehicle , output , ease of use (for me) and just the overall styling of the light. I like it a lot !!!!!!!!
****Note the runtime testing was terminated by me at 190 minutes as I was getting too sleepy to hold my eyes open at the time. I dont think the light would have lasted much longer though becasue the LVP would have turned it off I am sure very soon anyway with the cell at 2.79 volts already when I checked it at the time.
Much to my surprise the bezel wasn’t locked down with glue like I am used to seeing with Olight , so I was actually able to get to the emitter and test directly what the current was from there instead of trying to figure out how this new double tube design carries current to get a tail amp reading.
Below you will find the charts of the Runtime and Amperage testing (at the emitter) I did with the M2R , as well as the listed lumens and my actual tested lumens……….
For those who don’t want to see the whole video , the still pictures (I think 35 of them) of the light and the beamshots (12 of those)start at 11:26 of the video timeline and the outdoor live footage comparing the Olight H2R and the Manker E14 II starts at 16:32 of the video timeline.
The embed codes are not working here right now so here is the link to the video portion of the review on my Youtube channel.......
https://www.youtube.com/watch?v=-GxwMSOdNuA&feature=youtu.be
Here are some of the beamshots from the video portion of the review , first set is at 25 yards from gate and second set is at 50 yards...........
GENERAL DATA
Beam Distance (ft) 682
 Beam Distance (m) 208
 Max. Performance (lumens) 1500
 Charge type Magnetic USB charge base
 Compatible Batteries 1 × 18650 or 2 x CR123A
 Light Intensity (candela) 10880
 Light Form Compact/tight focused hotspot. Ultimate beam distance.
 Lens / Reflector Type Smooth reflector (central area and flood area)
 Mode Operation Dual Switch
 Form/Size Factor Medium size (Permanent Marker)
 Series Series M (Tactical, Military)
 Unique Characteristics •High voltage 3500mAh 18650 lithium ion battery included, deli vering a maximum output of 1,500 lumens.
•Comfortable and firm grip with ergonomic knurling allowing the user to operate the tailswitch naturally without even looking at it due to it’s smooth, barrier-less tail cap.
•Aside from momentary or constant turbo from the standard operation mode, the light also features an enhanced tactical mode for one click instant access to strobe.
•Compatible with all conventional 18650 batteries.
•Rechargeable through the included 5V 750mAh OLIGHT USB magnetic charging cable or the optional OLIGHT Micro-Dok (II or above).
LIGHTING LEVELS
LEVEL 1 (lumens) 1500
 Run-time LEVEL 1
 1050 lumens (~700lm);
 1h50m (3m).
 LEVEL 2 (lumens) 700
 Run-time LEVEL 2
 2h.
 LEVEL 3 (lumens) 250
 Run-time LEVEL 3
 6h15m.
 LEVEL 4 (lumens) 60
 Run-time LEVEL 4 20h.
 LEVEL 5 (lumens) 15
 Run-time LEVEL 5
 70h. LEVEL 6 (lumens) 1
 Run-time LEVEL 6
 25 days. Strobe Yes
 SOS / BEACON No
TECHNICAL CHARACTERISTICS
Waterproof IPX8
 Weight (g / oz) 149 / 5.26
 Length (mm / in) 130 / 5.12
 Head Diameter (mm / in) 25.4 / 1.00
 Body Diameter (mm / in) 24.4 / 0.96
 Led Cree XPH 35 HD
 Packaging Carton box
 Use Standard hotspot diameter with impressive distance. The perfect all-around beam profile.
 Package Contents •Olight M2R flashlight x 1
•Double Direction Stainless Steel Pocket Clip x 1
•10A HDC 3500mAh 18650 Battery x 1
•USB Magnetic Charging Cable x 1
•Lanyard x 1
•Holster x 1
•user manual x 1
« Last Edit: October 15, 2017, 12:51:31 AM by robo819 »
