Author Topic: Acebeam EC35 Bronze 1*18650 battery 1100 Lumens 300m distance  (Read 619 times)
Offline Acebeam
    • Acebeam
1:Cree XP-L High Intensity LED with a lifespan of 50,000hours 4000K
2:Use one 18650 or 2*CR123A batteries (not included)
3:Max output:1100 lumens
4:Working voltage: 2.7V-9V
5:136mm (Length)*25mm (BEZEL)*22(Body dia.)
6:Max beam 300 meters
7:Peak beam intensity 22500cd
8:206g weight (without batteries)
9:Smooth reflector gives perfect beam and throw.
10:Digitally regulated output- maintains constant brightness
11:Side switch on the head
12:Tactical tail switch with momentary-on function
13:Over-heat protection to avoid high-temperature of the surface
14:Made of  Bronze
15:Toughened ultra-clear glass lens with anti-reflective coating
16:Battery reverse protection function. And batteries low indicalion
 (it will flash when voltage down to 3v)
