Author Topic: Acebeam T16S Tactical Light Weapon mounted light  (Read 554 times)
Offline Acebeam
    • Acebeam
« on: June 15, 2017, 02:11:56 AM »
Features:
•Cree XP-L high intensity LEDs with lifespan 20yrs of runtimes
•Max output 1000lumens (1*18650 or 2*CR123A batteries)
•Output Modes (select by side switch)
        Mode 1:  Low      45 lms    (9hour)
         Mode 2:  Mid      420 lms   (3hour)
         Mode 3:  High     1000 lms   (1.5hour)
         Mode 4:  Strobe   1000 lms
•Working Voltage : 3V-12V
•Max beam distance: 309Meters
•Peak beam intensity: 23900cd
•Impact resistance:1.2Meters
•Waterproof to IPX-8 standard
•Size: 151.2mm(length)x35mm(head diameter)x25.4mm(tube diameter)
•Weight: 148g(without battery)
•Made of durable aircraft grade aluminum
•Premium Type III hard-anodized anti-abrasive finish
•Toughened ultra-clear glass lens with anti-reflective coating
•Copper base plate for more efficient heat
•Shiny smooth reflector and get perfect beam
•Inside of each box included:
        1x T16S Flashlight
        1x T16S nice gift package box
        2x Replacement O-rings
        1x Plastic rubber cap
        1x Removable SS clip
        1x User Manual
        1x Holster
        1x Lanyard
        1x Warranty Card
The above features to the right claim to ANSI/NEMA FL1-2009 Standards. Tests are performed with 1x 18650(3.7V  3400mAh)battery.
