Author Topic: CREEŽ XHP 70.2 LED Bulb Acebeam K30  (Read 781 times)
Offline Acebeam
    • Acebeam
« on: September 08, 2017, 02:18:21 AM »
LED:Cree XHP 70.2 LED with a lifespan of 50,000 hours
Maximum brightness:5200 lumens by using 3*18650 Battery
Firefly: 2lms,110hours
Low: 200lms,25hours
Mid: 600lms,10hours
High: 1350lms,4hours
Turbo: 2500lms--2000lms,2mins+2.1hours
Turbo Max: 5200lms--2000lms,2mins+1.8hours
Strobe: 2500lms,3.5hours
Working voltage: 9V to 12.6V
Max runtime: 110 hours
Max beam distance: 374 meters
Peak beam intensity: 35000cd
Impact resistant: 1.2 meters
Underwater 10 meters(The k30 is the most durable flashlight yet produced by Acebeam,
capable of surviving accidental immersion to extreme depths of up to 10 metres! However it is not a diving light,and should not be turned on or off underwater.);
Size: 120.2mm(length)x 48mm(head diameter)x 43mm(tube diameter)
Weight: 184g
Smooth reflector for max light output
Premium type III hard anodized and anti-abrasive finish
Ultra-clear tempered glass lens with anti-reflective coating,which achieves a 98.3% light transmittance
Strobe mode is for tactical and emergency use
Highly focused beam for maximum distance
Streamlined body design
Intelligent highly efficient circuit board design for max performance and long runtime
