Poll
I can't decided
Olight  X7R
0 (0%)
Ace Beam x80
1 (100%)
Thru Nite tn36 2017
0 (0%)
Total Members Voted: 1
Author Topic: What Pop Can should I buy?  (Read 3030 times)
Offline DJCHRISRECTOR
« on: January 17, 2018, 03:05:21 AM »
Help please
Offline SG-1
Re: What Pop Can should I buy?
« Reply #1 on: January 17, 2018, 05:54:50 AM »
I like both the AceBeam & Thru Nite because they use standard 18650 cells that could be swapped out "in the field" for extended run time. In the case of the ThruNite with the cost at nearly 5x less you could buy two & carry one as a full backup, light batteries & all.
« Reply #2 on: January 17, 2018, 07:27:37 AM »
Offline LuxHunter
« Reply #3 on: February 25, 2018, 03:49:19 AM »
You can't go wrong with the Q8, especially for the cost. I have four of them. With a few simple changes they put out close to 6,000 lumen and around 90k lux. But the UI is the best feature of the Q8.
I just bought a used Eagtac MX30L4Cvn with four XPL HI 4000K emitters which is now my go to light! At 5,200 lumen and 200k lux with a wonderful neutral tint, it is the most balanced light I have ever used. It is really a popcan thrower.
