Author Topic: Review : Nitecore Concept 1  (Read 1229 times)
« on: April 26, 2018, 03:26:37 AM »
Sent for review by Fasttech.com
Product Link @ Fasttech = http://shrsl.com/uiy7
Nitecore Concept 1:
 Right off the bat I just have to say this is the best walk around flashlight I have used to date . I really like my evening walks and often this means walking in the dark and having a good flashlight to walk with can mean the difference between a good walk or a bad walk .  The Concept 1 ( C1 from now on ) sits in the hand just so sweetly giving easy access to the on off switch . There is no need to to twist and turn the light , just very slightly movement of your thumb and you can turn the light on or off or activate the short cut to TURBO .
 The switch has to be held down for about one second to turn the light on , anything less and the light will not turn on . Once the light is on a quick press of the switch will turn the light off , or you may wish to press the switch and HOLD , doing so will short cut you to turbo and when you let go it will take you back to your chosen light level .  To chose a light level press the switch to turn on and HOLD , the light will now cycle through all the light levels and when you find one you like stop . The C1 will remember the light level you chose .
 The first thing I did with the C1 was take it for a walk , I settled on low mode ( 78 Lumens in my light box ) and found it to be almost perfect for my needs whilst walking . If I needed more light I simply pressed and HELD for TURBO ( 1600 Lumens with the Solarforce V3 Battery ) and let me tell you TURBO rules .  It's almost too much light , but when you want to see or be seen it really does the job .  TURBO , the C1 really pumps heat . You can hold the light about a foot away from your hand and feel the radiated heat from the emitter and the closer you hold the C1 to your bare hand the warmer it will be , to the point where it may actually burn you !  So when Nitecore suggests twisting the tailcap to break the circuit , I would respect that suggestion to stop accidental activation in say your pocket .
Performance :
 I used two batteries in testing the output of the C1 , a Solarforce V3 2600 18650 and a Sony VTC4 ...
 SOLARFORCE 18650
 Turbo = 1630 Lumen
 High = 982 Lumen
 Medium = 343 Lumen
 Low = 78 Lumen
 Ultra Low = 3 Lumen
 Sony VTC4
 Turbo = 1930 Lumen  ( 10 seconds later it was 1800 Lumen )
 High = 980 Lumen
 Medium = 341 Lumen
 Low = 77 Lumen
 Ultra Low = 3 Lumen
  This is a really small flashlight and I would suggest using Turbo sparingly as the heat produced is rather impressive at this level . Running turbo for about a minute the C1 was starting to get seriously warm , another minute and it may have been too hot to hold and the output does steadily decline as the light warms . So probably a great pocket warmer for those cold winter nights . But there could be repercussions if the light were accidentally turned on in Turbo mode .
  MODES
 We have one set of modes without the disco stuff ( Yay ) , but there is another set of modes that includes STROBE - SOS - BEACON for those who may want such . The light comes factory set ( I think ) for just the light levels and no Disco . To change over you break the circuit - open the tail cap or untwist the body . Hold the switch down while you twist the tail / body back to make contact . This will activate the flashy options .  To get to the disco modes you triple click the switch ( quickly ) and the light should be strobing your brains out .  To change modes ( SOS - BEACON ) press and hold the switch for about one second .
 SHORT CUT's
 There are several short cuts available
1) Double click the switch = Short cut to Ultra Low
2) Triple click the switch = Short cut to Turbo or start Disco modes ( Depending on the options the user choses )
3) With the light on = Press and hold the switch to short cut to TURBO
4) Any mode =  Click 3 times quickly to enter STROBE / SOS / BEACON
 BATTERY
 The Concept 1 does not like overly long batteries , I found that if the battery sits flush or near flush with the back of the body ( where the tailcap screws on ) the C1 simply refuses to work . Put in a shorter battery that leaves some clearance and there is no issue . My Solarforce V3 is some 67.5mm long and leaves a 3mm gap at the back of the body .  I have tried several longer protected batteries and the C1 simply would not run with them .
 THE SWITCH
 I really like the switch , but having seen quite a few reviews and the criticisms leveled at it , well ?  The switch is immensely easy to use , comfortable , intuitive , and can be used without the need to adjust or move the light in ones hands . And because the switch is so easy to use , it means that the light can be easily turned on or off ( Accidentally ) . One simply needs to be aware of the nature of the beast ! So if you plan on pocket carry please twist the tailcap / body so as to break the electrical circuit . ( Simple )
 EDC / Every Day Carry
 Simply yes , just unscrew the tailcap a little to break the electrical circuit and be happy with one of the smallest most powerful flashlights you can put in a pocket .
 Conclusion :
 I really like the Nitecore Concept 1 , it really ticks all the boxes for a walking light . It's incredibly easy to use , there is no need to shift the light in the hand to change modes or turn it on or off . One simply caries it comfortably in the hand ( Gloved even ) and shifts ones thumb slightly to make stuff happen and I really like that . The output @ TURBO does not hurt either , I mean it's embarrassingly bright and one feels almost obliged to apologize every time TURBO is activated . There are even Disco modes for those that seek lights with such , but for those who don't want such , well one simply ignores the option ( I really like that ) . There is just so much to like about the Concept 1 and so little not to . I have seen quite a few reviews on the C1 and I think that perhaps some are being a little nit picky or overly critical , but such is life . I am giving the C1 9 out of 10 ( 1 point lost for not liking longer 18650 ) .
 I would like the thank fasttech.com for sending me this little beast - I really like it and it has just become my walkies light .
  ( Youtube video )
« Last Edit: April 26, 2018, 03:27:17 AM by old4570 »
Offline ChibiM
    • eneloop101
Re: Review : Nitecore Concept 1
« Reply #1 on: April 26, 2018, 12:44:58 PM »
Hey, no audio :p   just joking ;)
« Reply #2 on: April 26, 2018, 12:54:56 PM »
Y = No audio !
  I stuffed up the audio , so went text !
 Just got myself a digital audio recorder so hopefully will be doing voice overs
Offline limphoni
« Reply #3 on: April 29, 2018, 06:57:12 AM »
At first, I thought my microphone is dead. Youtube video is nothing without audio. Instead of that, you could upload a couple of test images result isn't? I have used most of these Nitecore flashlights https://tacticalflashlightguide.com/nitecore/ but didn't yet Nitecore Concept series light. Thinking to buy this one very soon.
« Last Edit: December 13, 2018, 12:42:39 PM by limphoni »
« Reply #4 on: April 30, 2018, 01:24:13 AM »
1) Finding reliable image hosts and not paying $$
2) Slowly finding my way with the video ...
3) I will eventually get there ..
 Bottom line is I need to do the video just like they do in Bollywood , scene by scene then stitch it all together ...
What is that old saying , small bites !
 In my next review - I stuffed up the video ( for Audio ) because I did not do it scene by scene .. ( Live and learn ) ...
One more flashlight review to go ..
