Author Topic: Fenix LD15R - Unique and Popular Right Angle Flashlight  (Read 193 times)
« on: August 06, 2018, 03:17:40 AM »
Fenix LD15R flashlight is a compact and handy right-angle flashlight with dual light sources: white and red lights. Powered by one 16340 rechargeable Li-ion battery, it is also compatible with a cold-resistant CR123A battery. The large pushbutton switch located on the top of the light makes for easy operation, it delivers a max output of 500 lumens and a max beam distance of 85 meters. Featuring four white and three red light output levels, plus Micro USB charging, battery level indication, two-way body clip and a magnetic tail, the LD15R will be a good aide for repair work, outdoor activities and daily use.
● Cree XP-G3 white LED with lifespan of 50,000 hours.
● Primary white LED for general illumination plus low light red LED preserves night vision:
    ☼ Turbo - 500 lumens, 1.3 hour accumulated runtime (downshifts to 200L after 5 minutes)
    ☼ High - 150 lumens, 2 hour runtime, 123 meter beam range
    ☼ Medium - 30 lumens, 13.3 hour runtime
    ☼ Low - 3 lumens, 110 hour runtime
    ☼ Red - 4 lumens, 30 hour runtime
    ☼ Red Signal (slow flashing)
    ☼ Red SOS
● Maximum beam range of 278 feet in Turbo (85 meters).
● Waterproof (not dive rated).
● Powered by one 16340 rechargeable Li-ion battery or CR123A Lithium battery.
● 5V/1A Micro USB charging, 1.5 hour charging time.
● Battery level indication.
● Digitally regulated output maintains constant brightness.
● Two-way body clip and magnetic tail.
● Reverse polarity protection to protect from improper battery insertion.
● Low-voltage warning reminds when battery replacement is needed.
● Made of durable high-strength and oxidation-resistance aluminum.
● Constructed of aircraft grade aluminum with premium type HAIII hard-anodized anti-abrasive finish.
● Fitted with high quality optical lens.
● Heat control circuitry when using Turbo prevents damage to the LED
    ▹ Brightness drops to 200 lumens after 5 consecutive minutes in Turbo.
● Battery status indicator in switch
    ▹ From off, click the switch; indicator will show battery status for 3 seconds.
● Pushbutton switch (located on top)
    ▹ Press and hold switch for 0.5 seconds for on or off.
    ▹ From on, quick press to change brightness level.
    ▹ Press and hold switch for 1.2 seconds for red.
This is the first right angle flashlight on GearVita, it is unique. Nowadays, right angle flashlights are becoming quite popular. Compared to traditional flashlights where the lens and body are parallel to each other, a right angle has a head that's positioned 90 degrees to the body. This style of lights are good because they incorporate some abilities and features you don't see on the standard lights. You can buy it here: https://gearvita.com/fenix-ld15r-right-angle-flashlight-500-lumen.html
https://gearvita.com/fenix-ld02-mini-led-flashlight-100-lumens.html
https://gearvita.com/fenix-uc35-v2-0-usb-rechargeable-flashlight-1000-lumens.html
