Author Topic: Manker PL21 Penlight - Small Body Gathers Big Power  (Read 171 times)
« on: August 10, 2018, 11:27:23 AM »
The Manker PL21 penlight is a practical pen lamp that is always at hand thanks to the clip in the shirt or in the trouser pocket. The penlight benefits from a slim body which can get into those tight corners a larger flashlight would struggle with. It adds to this feature with three light levels, the lower of which will not blind you when you're in that tight corner searching for a contact lens! However, turn it to the higher 200 lumen output and it will light up a room.
Powered by just two AAA batteries (not supplied), with an aircraft-grade aluminium body and a runtime of 47 hours on the low setting, this is all the lighting you'll need during your working day.
It is now available for purchase on GearVita with the price of only $24.68 by using the coupon code "MANKPL21", offer lasts until 20th.
Main Parameters:
Emitter: CREE XPG3 / Nichia 219C LED
Maximum 200 lumens output
Maximum beam intensity: 1000cd
Maximum beam distance:63meters
Working voltage: 1.8 - 3.2v
Power by 2x AAA batteries (battery not included)
Driver: most efficiency constant current circuit
Material: Aircraft-grade aluminum body
Surface treatment: premium type III hard-anodized anti-abrasive finish
Aerospace grade aluminium alloy construction
Waterproof: IPX-8 (2 meter under water)
Impact resistance: 2meters
Size: 133mm length x 14mm head diameter
Weight: 29g (without battery)
Brightness Levels and Runtime:
Low: 4lm / 47hrs
Mid: 58lm / 4.5hrs
High: 200lm / 40min
Strobe: 200lm
● Unique design with simple but beautiful handles, easy to use, just like a pen.
● Made of durable aircraft grade aluminum.
● Adopts CREE XPG3 LED, maximum 200 lumens output.
● Maximum light duration of 47 hours.
● Peak beam intensity 1000cd, max beam 63 meters, impact resistance 2 meters.
● Bottom switch and clip is stainless steel, strong and durable.
● Three different light modes and strobe mode.
● High-quality processing water and shock resistant.
● Driver is the most efficiency constant current circuit.
Product link: https://gearvita.com/manker-pl21-led-penlight-200-lumens.html
Manker PL21 is a light, small and powerful penlight, although the body is small that may look unremarkable, but it can provide sufficient light. With it, you won't worry about working on the vehicle or taking a walk at night because it will always illuminate your surroundings.
