Author Topic: Enjoy Fun Riding with Fenix BC35R Bike Light  (Read 169 times)
« on: September 08, 2018, 09:56:00 AM »
The Fenix BC35R is an all-round USB rechargeable bicycle light. The max output is 1800 lumens, making it a tough performer not only for city commuting, but also for country cycling. The innovative cut-off facula line guarantees safer cycling by not dazzling oncoming traffic, whether on foot or in vehicles. The OLED screen displays the current output and corresponding runtime, thus riders are constantly aware of the bicycle light status. The remote pressure switch makes instant operation possible during cycling, and changing road conditions can be abruptly dealt with. The Fenix BC35R bike light has built-in anti-theft protection which smartly monitors users' bicycles. Moving the bicycle will set off an alarm, also helpful when a potential danger or emergency is encountered.
LED: Cree XHP50 neutral white LED
Max Output: 1800 lumens
Max Distance: 146m
Output Modes: 6
Impact Resistance:1m
Waterproof: IP66
Batteries: Built-in 5200mAh/3.7V rechargeable battery
Brightness Levels and Runtime:
Burst: 1800 lumens
Turbo: 1100 lumens ( 2.2h** )
High: 400 lumens ( 6.5h )
Med: 150 lumens ( 12h )
Low: 45 lumens ( 28h )
Flash: 150 lumens
● Cree XHP50 LED offers even and soft neutral white beam - better for color rendering and vision protection.
● Orange-peel reflector makes every corner is clearer to sight and darkness is nowhere to hide.
● Max 1800 lumens output and 146m beam distance, guarantee safe cycling with better vision.
● The rechargeable built-in 5200mAh Li-ion battery offers max runtime of 28 hours. Standard micro USB charging port, charge as you like anywhere.
● Anti-glare cut-off facula line for safer cycling.
● Equipped with extra remote pressure switch - conveniently select desired output and activate.
● The user-friendly OLED screen displays current output and corresponding runtime, thus user is constantly aware of the bicycle light status, making the rider well-prepared for on-going riding trip.
● Intelligent anti-theft protection funtion smartly monitors bicycles, once the security key is removed, moving the bicycle will set off a piercing alarm.
● The functional switch will flash red when the runtime of low output level is less than 10 minutes.
● Overheat protection - The light will accumulate a lot of heat when working on Turbo mode. The light will automatically step down to a lower brightness level to reduce the temperature, but turbo mode can be reselected.
● Low-voltage warning - When the voltage level drops below a present level, the bicycle light is programmed to step down to the next lower brightness level until low output is reached.
● Quick-release light mount.
● High-strength aluminum body.
● IP66 rated dustproof totally protected against dust and foreign objects, waterproof can withstand heavy rain and splashing.
Applying the coupon code "FNBC35R", you can buy this bicycle light of $99.88 on GearVita. Grab your BC35R and don't miss the opportunity to have fun riding: https://gearvita.com/fenix-bc35r-led-bike-light-1800lm.html
https://gearvita.com/fenix-bc30r-led-bike-light-1800lm.html
https://gearvita.com/fenix-bc30-led-bike-light-1800lm.html
