Author Topic: Acebeam M20 - Inconspicuous But with Great Role  (Read 148 times)
« on: September 10, 2018, 07:53:19 AM »
Acebeam M20 flashlight may not be the biggest, but it is a high-powered keychain flashlight and lives up to Acebeam's legacy of quality products. Featuring a CREE XPG3-S5 LED and powered by a single AAA battery, this diminutive dynamo can produce up to 150 Lumens of incredible light output. An intelligently designed and highly efficient printed circuit board improves the performance of the equipment and maximizes its operating time, automatically providing protection against damage caused by high temperatures. By twisting the light head, you can select middle, low and high three unique lighting modes rapidly that can adapt to indoor or outdoor use. With the included keychain mount the Acebeam M20 can be hooked to any set of keys or even clothing for a portable hands free carry, it is your ideal partner whenever and wherever you need light.
LED: CREE XPG3-S5
Power Source: 1 x AAA
Working Voltage: 0.9 - 1.5V
Max Output: 150 lumens
Max Runtime: 25 hours
Peak Beam Intensity: 628cd
Peak Beam Distance: 50 meters (164 ft.)
IPX Rating: IPX-8 waterproof (2 meter submersible)
Impact Resistance: 1.2 meters (3.9 ft.)
Brightness Levels and Runtime:
High: 150 lumens ( 0.8 hours )
Medium: 30 lumens ( 4 hours )
Low: 2 lumens ( 25 hours )
● Use CREE XPG3-S5 LED light temperature of 6500K, maximum brightness of 150 lumens, maximum intensity of 628cd, wide beam of 50m, LED life of 50,000 hours.
● Crafted from durable, lightweight aircraft grade aluminum.
● Premium type III hard-anodized anti-abrasive finish is hard-rusted, heat-resistant.
● 2mm toughened ultra-clear glass lens with anti-reflective coating reduces glare, provides 98.3% light transmission evenly at all brightness levels.
● Special gold-plated contact system for maximum power impact strength of 1.2m.
● Waterproof to IPX-8 standard at 2 meter depth.
● Copper base plate for efficient heat management.
● Moderately texturing finished reflector disperses light for a smooth, even beam.
● High-performance circuit design, low power consumption, voltage 0.9 - 1.5V, use AAA alkaline batteries.
● The ability to stabilize the flashlight on a flat surface to fulfill the role of a candle.
A flashlight on your keychain can be negligible but until you suddenly need light in a dark room, on the side of the road, etc, you will thank its great role. Acebeam M20 is such a keychain flashlight that is inconspicuous but can play a huge role at a critical moment. It is available in three colors on GearVita, including black, brown, and silver. If you're looking for a daily use flashlight with powerful capabilities and a long service life, as well as the smallest possible size, it will be an invaluable companion for you: https://gearvita.com/acebeam-m20-led-flashlight-150-lumens.html
https://gearvita.com/acebeam-uc15-keychain-light-1000-lumen.html
https://gearvita.com/olight-i1r-eos-led-keychain-flashlight-130-lumens-rechargeable.html
