Author Topic: Tank007 WF01 Rechargeable Wearable Flashlight with Rotatable Head  (Read 63 times)
« on: September 13, 2018, 08:28:49 AM »
Tank007 WF01 flashlight is a compact and portable flat wearable lamp, which can be rotated 180 degrees, easy to adjust the light direction, in small size like a lighter. The body comes with a metal clip, easy to use and to carry in a variety of ways. In addition to holding in hand, other using methods including but not limited to hanging in the neck lighting, clamping hat brim, badges, pockets, belts, etc.
LED: USA Cree XP-G2
LED Lifespan: above 100,000 hours
Max Brightness: 280 lumens
Throw Beam: Above 50m
Lens: Tempering optical lens
Power Source: Built-in 250mAh rechargeable lithium-ion battery
Output Level: Two mode types (the two types switch by quick clicking the switch):
▹ High - mid - low
▹ Strobe - Blink 0.5Hz - SOS
Burn Time:
▹ High light - 1 hour
▹ Medium light - 3 hours
▹ Low light - 34 hours
Waterproof: IPX-6
Anti Dropping Height: 1.5m
● 180 degree lighting to adjust beam direction to meet different needs.
● The size is as small as a lighter, convenient to carry.
● Using aluminum material, it is non-slip, waterproof, and abrasion resistance.
● LED will give you stable and bright light, nonthermal radiation, safe and reliable.
Tank007 WF01 comes with a metal clip, easy to use and various ways of carrying.
● Built-in high-energy polymer battery, which can be charged through the micro-USB port from the side.
● Built-in charge protection circuit which can stop charging in case of over discharge, overcharge, short circuit to further protect the battery.
● With memory drive circuit, the flashlight can remember commonly used modes.
● Comes with low power indicators, the red light flashes 3 times every 3 seconds at the frequency of 3Hz in the on-state when the power level is lower than 10 percent.
● Can be used as a signal light, double-click switch to turn on the signal light when the light is off, the red and green light will flash in turns. Click the switch once to power off the signal light. This can facilitate to find the flashlight in the dark (if the signal lights are in work process, click the button to exit the flash mode).
● When the flashlight is powered on, each time the power indicator is flashing, it indicates the power level - 100 percent flash 5 times, 75 percent flash 4 times, 50 percent flash 3 times, 25 percent flash 2 times, less than 10 percent does not flash.
● Suitable for camping, fishing, hunting, hiking, searching, working.
WF01 is a new type of mini flashlight, which can be worn to your hat, sleeve, pocket, etc. It is small in size but bright in night and now available on GearVita, you can purchase it online: https://gearvita.com/tank007-wf01-mini-wearable-flashlight-280-lumens.html
https://gearvita.com/nitecore-tip-ss-stainless-steel-metallic-keychain-flashlight-360lm.html
https://gearvita.com/acebeam-uc15-keychain-light-1000-lumen.html
