Author Topic: Quality alternative headtorch to BORUIT RECHARGEABLE CREE 13000 ?  (Read 621 times)
Offline zillah
Dear Experts
I work night shift and I have been using BORUIT RECHARGEABLE CREE 13000LM for about one and half years which is not a quality head torch bought it from ebay
https://www.ebay.com.au/itm/BORUIT-UPGRADED-RECHARGEABLE-CREE-13000LM-3T6-3X-XM-L2-LED-HEADLAMP-TORCH-USB/302095643393?epid=886556492&hash=item46564db301:g:gKAAAOSwwKxbtNGe:rk:1:pf:0
The BORUIT has super bright light ,,,,,,Which alternative quality head torch with super bright light and using 18650 batteries would you recommend ??
Preferable but not must ebay sellers as I am not based in USA
Thanks
Re: Quality alternative headtorch to BORUIT RECHARGEABLE CREE 13000 ?
« Reply #1 on: November 07, 2018, 08:02:48 AM »
First what is the Price range you are comfortable with for a "quality" headlamp? Other than 18650 cell , What are some of your ideas on what you want such as , features , size , UI? Are you wanting something with a separate head and battery carrier , or is a one piece design with 90 degree head OK? Are you wanting a more throwy headlamp , more floody or a balance of the 2? Any certain type of work or use you use the light for?
« Last Edit: November 07, 2018, 08:08:06 AM by robo819 »
Offline zillah
« Reply #2 on: November 07, 2018, 08:49:37 AM »
Thanks Rob
Quote
Not more than $200
Quote
May be because I have been using them ..there are other I am not familiar with them
Quote
The one in the ebay link is okay for me
Quote
Balance of the 2
Quote
Night shift work
Some area has light but not adequate to read plan or drawing
And some time I work in a bush where we do construction sites I need to see within 50 meter
Regards
« Reply #3 on: November 07, 2018, 09:48:48 PM »
Well as far as the headlamps I have personally had experience with or reviewed (I think 11 of them now) , the 2 that are at the top of my list are the Olight H2R and the Thrunite TH30 , both very powerful headlamps. There are a lot of headlamps on the market now days and I am sure some of the other big name companies have some headlamps that are of good quality also.
I am just going on what I have reviewed and that i have personally though. Both of these lights are well under the $200 price you mentioned and both are great quality lights with onboard charging , included cell and charging cord. The Olight with magnetic tail charger and the Thrunite with USB side port charging. So far out of ALL the Olight and Thrunite products I have , or have reviewed , I think all of them are great build quality and both companies stand behind their products.
I am NOT affiliated with either company and simply like to review flashlights , so I do my best to give an unbiased and honest opinion in all my reviews.
Both should be available on Ebay also.
Here are those 2 reviews...........
http://theflashlightforum.com/index.php?topic=1146.msg6947#msg6947
http://theflashlightforum.com/index.php?topic=1351.msg7540#msg7540
« Last Edit: November 07, 2018, 09:54:56 PM by robo819 »
Offline zillah
« Reply #4 on: November 07, 2018, 09:52:43 PM »
Thanks Rob appreciate your dedicated time to help and direct me to the right products
« Reply #5 on: November 07, 2018, 09:59:46 PM »
No problems glad to help........I corrected the Olight review link just now.........had the M1T warrior there at first by mistake
Offline zillah
« Reply #6 on: November 08, 2018, 09:28:39 AM »
One more question Rob
Olight is 2300 lumens and ThruNite TH30 is 3350 lumens,,,do you feel difference in the brightness ?
Thx
« Reply #7 on: November 08, 2018, 01:28:14 PM »
Yes , but the beams are different at the same time. The Olight has the honeycomb TIR optic in it , where the Thrunite has the Orange Peel reflector. The Olight concentrates the light a little more it seems , while the Thrunite makes just a massive wall of light in a broader area.
Both are good for out to around 80 to 100 yards of decent light to see with , but the Thrunite does make the larger coverage area.
Offline lightknot
    • Four Leaf Flashlights
« Reply #8 on: November 08, 2018, 04:16:08 PM »
You might want to check out Spark and Zebralight options as well.
Looks like a Surefire kind of day..
