Author Topic: Xiaomi Mijia Smart Bedside Lamp - Dream in 16 Million Colors  (Read 64 times)
« on: December 04, 2018, 03:31:55 AM »
This Xiaomi Mijia smart bedside lamp uses high CRI osram LED, offering16 million RGBW lights for your year-round choice. With simply touch and slide, you can adjust brightness and colors as you deisred. Also, special lights design provides you different scenarios. Moreover, you can control the lamp for more fun using delicated App.
● Magic Colors
A tremendous range of 16 million colors for choise.
● Dimmable
Adjust color temperature and brightness for suitable light.
● Color Temperature
1700K-6500K color temperature gradual change function.
● Perfect CRI
Professional optical design with high-quality Osram LED that of high color rendering index.
● Touch Control
Simple touch to adjust brightness/change color/delay switch off/switch light mode as you desired.
● Smartphone Controls
Can be controlled by smartphones through WiFi or bluetooth. Built in multiple scene modes, the porprietary APP lets you get access to your desired lighting easily.
● Mi Band Linkage
Through the MIJIA APP, the bedside lamp and your Mi band binding, then it will be based on your sleep state to determine whether or not to turn off the lights, no longer interrupt your hazy sleepy.
● High-quality Manufacturing
Uses high-precision CNC anodized blasting and cutting techniques to ensure flawless construction.
Every bedroom requires something a little different, this Mijia bedside lamp's minimalist design is perfect for every bedroom. Get it from GearVita and start a colorful life: https://gearvita.com/original-xiaomi-mijia-led-smart-light-bedside-touch-control-bluetooth-dimmable-lamp.html
Hot sale products:
cheap xiaomi mi 8 lite 64gb
cheap xiaomi mi band 3 smart bracelet heart rate monitor
