Author Topic: Xiaomi Mijia Aqara Hub Gateway Provides You A Smarter and Safer Home  (Read 73 times)
The new Xiaomi Mijia Aqara Hub Gateway can works with Apple HomeKit, which means you will be able to control their smart products with the Siri voice assistant. It can be linked with up to 32 smart devices including smart lights, the Aqara flood sensor, wireless switches, wall sockets, body sensor, temperature and humidity sensor, and Aqara motorized curtain. When connected to the Apple HomeKit, you will be able to use Siri on their iPhone, iPad, Apple Watch or HomePod to control any of the smart devices.
● Smart Home Center
Aqara Hub is a control center for an entire smart home. Connecting via Zigbee protocol, Aqara accessories can still work smoothly even if your home network is unstable or disconnected.
● Works with Apple HomeKit
You can use Home app to control the Hub and its connected accessories. Aqara accessories can also work with other HomeKit-enabled accessories to provide you a smarter home.
● Siri Voice Control
You can control Aqara accessories with Siri on your iPhone, iPad, Apple Watch or HomePod. Just tell Siri "I'm home", then the lights turn on, the curtains are closed, and a comfortable home is waiting for you.
● Nightlight Function
When motion is detected in the evening, the Hub light automatically turns on.
● Smart Doorbell, Personalized Ringtone
With a press of the wireless mini switch, the hub plays your preferred ringtone.
● Security Reminder, Guarding Your Home
With the door and window sensor, you can turn on alarm mode when you leave the house or you are asleep. If a door or window is opened, the hub will sound an alarm and send your phone.
● One Button, All Accessories Under Control
With the wireless remote switch, set your own night mode and turn off all by one button.
● Humidity and Temperature Adjustment
Link the smart plug with a humidifier to improve indoor humidity.
● Water Leak Alarm
With the water leak sensor, when a leak is detected, the hub will sound an alarm and send a notification to your phone.
● App Control
With the Aqara Home App (IOS or Android), you can control your home from almost anywhere at any time.
● Technologically Advanced
Aqara hub adopts one body shell design and uses NXP i.MX6 CPU, 256M DRAM, 256M flash, and an MFi chip. It has two high gain built-in antennas. By utilizing FR4 PCB with a large area ventilated base, the ventilation creates an airflow from front to back, increasing the heat dissipation and ensuring the hub's reliability over time.
If you are interested in grabbing one, it is available for purchase on the GearVita store: https://gearvita.com/xiaomi-mijia-aqara-hub-gateway.html
You may also like:
best xiaomi mi 8 lite 128gb
buy xiaomi airdots bluetooth headset
