Author Topic: Xiaomi Philips Smart E14 LED Candle Bulb Illuminates Every Corner of Your Home  (Read 70 times)
The Xiaomi Philips smart E14 LED bulb comes with  8 LEDs whose brightness and sharpness can be adjustable, widely used for indoor lighting decorations. With only 3.5W consumption, the bulb is safe and energy-saving. The candle bulb can be controlled by APP, turn on and turn off the switch, brighten and dim the brightness, you can simply use your smartphone to do all that. It is made of a high-quality plastic material,  to ensure ultra-long lifetime that is up to 10 years.
● Crystal Version, Bright as Star Light
The shell is made of high transmission engineering plastics, clean and transport. The lotus-shaped lens inner can fully reflect and refract the light beam, emit a star-like bright light for you.
● Scrub Version, Soft as Moonlight
The shell is made of opal plastic, after full reflection and filter of milky white shell, light beams are softer, the same as gentle moonlight.
● E14 Holder, Match with Varieties of Lamps
Equipped with a standard E14 holder, the bulb can be directly replaced the traditional E14 bulbs and brighten every comer of your home to give your home a new glow.
● Adjustable Color Temperature and Brightness to Create Personalized Lighting Scenes
3000-5700K color temperature and brightness can be adjusted in the Mijia APP via WiFi. In addition, there are 4 scenes for you to choose.
● Delay-off Function, Let the Darkness Come Later
According to your settings, the light bulb can be delayed off at any time within 6 hours, let the dark come later.
● Smart Linkage, Lighting More Intelligent
The light bulb can be used in conjunction with Xiaomi other smart products for more functionality. With Xiaomi body sensor and windows and doors sensor, the bulb will automatically turn on when someone passes through a specific location or switches the doors or windows.
● 10-year Lifespan to Provide You Longer Lighting
15000 hours life, not only environmental friendly but also keeping you away from replacing bulb frequently.
● 3 Steps, Easy to Use
Install the bulb, download Mijia APP, find and add devices via WiFi.
It comes in two version, the crystal or scrub version, both can be found on GearVita at $14.99 and offer the best when it comes to lighting experience: https://gearvita.com/xiaomi-philips-zhirui-smart-e14-led-candle-bulb.html
You may also like:
cheap xiaomi mijia aqara hub gateway
best xiaomi redmi note 5
