Author Topic: On The Road U16 Mini Flashlight - 1020 Lumens, 140h Runtime  (Read 77 times)
« on: January 11, 2019, 04:40:27 AM »
On The Road U16 flashlight is a USB rechargeable mini flashlight, it is a USB charging version of M3, the functions are consistent with M3, and USB direct charging is added.
● Compact in mini size, easy and convenient to carry.
● The side switch controls five brightness and three special modes.
● When installed one 700mAh 16340 Li-ion battery, the flashlight can be used for 140 hours in low mode.
● CR123A battery and RCR123 batter are also suitable for this flashlight.
● High efficiency constant current circuit board always provides a sense of security.
● After twisting the tail cap, you can clean the memory by changing to month mode.
● Ultra-clear mineral glass with antireflective coating.
● The integrated power indicator on the switch shows the remaining battery power.
● HAII Military grade hard alumite finish aero grade aluminum alloy.
● Has the function of low voltage reminder indicates and reverse polarity protection to protect the light from the damage of improper battery installation.
● Magnetic tail cap with stand function.
● Safe and water resistant, highest water resistant level of IPX6, impact resistance up to 2 meters.
The On the Road U16 is a compact, capable, well made flashlight. For $27.99 on GearVita, it has good value: https://gearvita.com/on-the-road-u16-u3-1a-mini-led-flashlight-1020-lumens.html
Top sellers on our website:
cheap xiaomi airdots headset
best lenovo z5 pro 64gb
