Author Topic: Xiaomi Yeelight YLSD03YL LED Downlight - Home Improvement New Choice  (Read 79 times)
The Yeelight YLSD03YL LED downlight, a ceiling lamp with excellent brightness. It is manufactured from thickened metal to provide a lightweight body, has corrosion and discoloration resistance characteristics. It selects a high quality LED as a light source and high transparency metal as a screen. The material is definitely high quality and the workmanship with which it was made is excellent. This Yeelight LED downlight has an integrated heat dissipation structure, thickening material can effectively promote heat dissipation and at the same time keep the source separate from the heating components to ensure a very long service life.
● Superior in Material, Excellent in Workmanship
Use thickened metal as light body with the features of rust-proof and fading-resistant, select high-quality LED as light source and high-transparency material as lampshade.
● Multiple Protection
Built-in constant current driver to give overload protection, short circuit protection, under-voltage protection.
● Integrated Heat-dissipation Structure
Thicken material can effectively promote heat dissipation and simultaneously and keep source apart from heating components to ensure long lifespan.
● Energy-saving and Long Lifespan
Provide 400 lumens brightness with only 5 wattage, quite energy-saving yet highly bright 25000h effective working time, practical and durable.
● Render The Brilliant Colors
Render the original color of objects and effectively eliminate the impact from low color rendering index on vision.
● Simple Yet All-matched Design
Designed in round shape in classic white, can easily match with a variety of home style, comes with a curved light-emitting surface to divergent a softer light.
Yeelight LED downlight installed in the corridor, aisle, entrance and other small space at home, the warm and gentle light can lighting this place. It do not to take to much space and money, only $10.99 needed on GearVita, but will be able to create a comfortable and warm atmosphere: https://gearvita.com/xiaomi-yeelight-5w-400lm-4000k-led-downlight.html
Top sellers on our website:
xiaomi huami amazfit bip smartwatch
qcy t1c mini wireless earphones in stock
Offline Johnmager
Presented in the profile to view as well as the needs of the people it quite well.
