Author Topic: Yeelight YLXD01YL Smart LED Ceiling Light Makes Life More Comfortable  (Read 62 times)
The Xiaomi Yeelight YLXD01YL smart ceiling light is deigned as sporting white color in a circular shape. It equipped with 240pcs OSRAM LEDs of a color rendering index that is up to 95Ra, providing museum lighting effect. The dual-chip three-way dimming system allows a flexible adjustment of brightness and color temperature. In addition, a moonlight mode which gives the look of the moon when turned on is surprisingly comfortable. Being a smart lamp, the light can be controlled by smartphones through WiFi or Bluetooth. It also comes with a Bluetooth remote controller that allows you to remotely switch on and off your light without necessarily being in the same room. What's more, a innovative quick coupler module lets you push and slide to lock the lamp into holder with ease. Ever since then, life is surprisingly easy!
● Museum Lighting Effect
Equipped with 240pcs high-grade OSRAM LEDs of a color rendering index that is up to 95Ra, providing museum lighting effect.
● Cozy Moonlight Mode
Moonlight mode which gives the look of the moon when turned on is surprisingly comfortable. With brightness down to 0.1 lumen, it reduces glare and mitigates eyestrain.
● Dual-chip Three-way Dimming System
Color temperature range from 2700K to 6500K, brightness range from 0.1lm to 2000lm, and you can adjust them freely.
● 5 Mins Fast Installation
Innovative coupler module for quick assemble and disassemble ( II electric shock-resistant ), simple and convenient (compatible with 50-100mm lamp holder).
● Mi Band Linkage
Through Mijia APP or Yeelight APP, connecting with Mi Band, it can track when the user starts to fall asleep and turn off automatically.
● App Remote Control
Get access to preset scenes in Yeelight APP. Sun rise mode, Sun set mode and selfie mode, save your favorite light settings and recall them whenever you want with the tap of a finger.
● Bluetooth Remote Control
Bluetooth remote controller allows you to remotely switch on and off, adjust brightness and color temperature freely.
● 25000 Hours Lifetime
Aluminum rear plate, copper clips, 450 parts and 96 working procedures, providing high quality lighting.
● Efficient Heat Dissipation
Unibody aluminum plate, 1.1℃/W saturation thermal resistance, highly efficient cooling reduces light wane and ensures LED lifetime.
● IP60 Dustproof Grade
Protects the light from dust, and could get rid of the pesky insects.
Get this Yeelight ceiling light from GearVita, it will accompany you while reading a book in the evening, it also helps you relax before going to bed or creates a more festive atmosphere: https://gearvita.com/xiaomi-yeelight-ylxd01yl-smart-led-ceiling-light-with-remote-control.html
You may also like:
cheap xiaomi redmi 6a global version
best oneplus 6T 4g smartphone 256gb
