Author Topic: Shift from 18650 to 21700  (Read 4782 times)
Offline lightknight
« on: March 12, 2019, 08:54:09 AM »
Hello Everyone
I am new in this forum and have already a question.
Do you know why many flashlight producers slowly start shifting toward 21700 types instead of remaining on 18650?
I know that 21700 have more possible capacity than the 18650 but are there any other profits?
Glad to hear your opinion on this subject.
Offline macka17
Re: Shift from 18650 to 21700
« Reply #1 on: March 27, 2019, 04:37:53 AM »
Different people think different ways. on all items.
Myself. I use 10440/123A 14550 18650 26650 etc.
But never got to like or use the 2000/21000 series.
I can't honestly say they worth even looking at. Basically TOO similar to the 18650.
It's just dealers/mfg's trying to make another segment of a small market to have "some" people buy a few more battery's.
18650 cover MOST of the hand held electrical output market.
SOME  (A LOT) find them a bit skinny in the hand to hold. whereas the 26650 fit much more comfortably.
The 21000 ser are NO thicker. to hold. with only a slight  capacity advantage.
Why. Really.... Bother?.
Offline mtnbst
« Reply #2 on: April 07, 2020, 05:48:36 PM »
I'm noticing significantly longer run times with 21700 vs 18650 especially on medium. Ex... olight heat seeker 2pro,  300 lumens (9.5 hours) not bad....
« Reply #3 on: June 17, 2020, 10:56:43 PM »
To me the 21700 are brilliant. With the new super high output pocket monsters available, the 21700 offer the capacity of a 26650 with just the slightest increase in size over the 18650. Compared to 18650 the 21700 offer greater capacity, higher output in amps (40A or more compared to 20-30A at best, and less voltage sag. Everything Macka17 lists as a negative I only see as a positive. I have a lot of 26650 lights and I edc none of them because they are too fat to fit comfortably in my pant pocket.
My S2+ is a regular edc choice for me but I want an S21 in a bad way because it is only slightly thicker and  at least 50% more capacity than the 18650 in my S2+. I say get used to the 21700 because itís likely here to stay and for very good reason.
« Last Edit: June 17, 2020, 10:58:40 PM by JohnnyMac »
Offline randomuserperson
« Reply #4 on: July 23, 2020, 12:50:26 PM »
Just joined to check a for sale ad, this caught my eye though....
If I run a 3500mah 18650 in my light, but decide to remove the adaptor and run a 5000mah 21700.... that 1500mah is only a slight increase in capacity??
« Reply #5 on: July 27, 2020, 02:37:12 AM »
That 1500 mAh is around 40% increase over the 3500mAh. 35-40% more runtime and little difference in size? Sounds like a no brainer to me. All your negatives about it honestly seem like positives to me, especially with 3000-4000 lumen edc lights where the extra amperage is needed. 3500mAh 18650 can only supply 10A at best. A 21700 will easily sustain 20A.   Just my take on it.
