Author Topic: ThruNite Turbo Mode Test  (Read 558 times)
Offline Nakme
« on: September 28, 2020, 12:36:01 AM »
Every time i got a new Flashlight i test Turbo mode to see how it behaves...
Testing is very simple, i Turn on The turbo mode and measure and collect data...
I monitor with light sensor how the light behaves (drops down lumens, stay stable...)...
Down here are some of my tests... and I hope that it will help someone to learn more about the lights I tested...
Lumens values are relative to the values claimed by ThruNite... I did not measure Lumens, just the duration and dropping down of lumens...
I have a question for more experienced members:
My testing means that I turn on the Flashlight in Turbo mode and leave it until it turn off or go to firefly mode...
Flashlights got very hot after some time, but i do not turn it off, I let them run until they turn off...
Is this kind of testing bad for flashlight, and can I damage the light with that...?
I usually do not use turbo mode for long times in real life... only when I test them...
So my question is: Did I damaged my lights in some way because of this one time test run on Turbo Full Time...!
ThruNite TH01
Output & Runtime Claimed by ThruNite (Tested with ThruNite 1100mAh 18350 battery):
Turbo (1500-430 lumen; 5 mins+80 mins)
High (450 lumen; 3 hrs)
Output & Runtime - Measured: (Tested with ThruNite 1100mAh 18350 battery):
Turbo (1500 lumen 3 min. + 1000 lumen 3 min. + 450 lumen 50 min + 250 lumen 2-3 min - Red Light Flash)
High (450 lumen 1h:10min. + 250 lumen 2-3min. - Red Light Flash)
ThruNite T1
Output mode/Runtime Claimed by ThruNite (Tested with ThruNite 1100mAh 18350 battery):
Turbo: 1500Lm-408Lm (3mins+52mins)
Infinity High: 685Lm(65 minutes)
Output mode/Runtime - Measured: (Tested with ThruNite 1100mAh 18350 battery)
Turbo (1500 lumen 1min. + 1400-700 lumen 1min. + 700-430 lumen 1min. + 430 lumen 1h + 230 lumen 1-2min. - Red Light Flash)
Infinity High (685 lumen 8min. + 430lumen 1h. + Red Light - 230 lumen 1-2 min. - Red Light Flash)
ThruNite Neutron 2C V3
Output mode/Runtime Claimed by ThruNite (Tested with ThruNite 3400mAh 18650 battery):
Turbo (1100 lumens / 2.2 hrs)
Turbo (1100-650 lumens 1h:10min. + 650-OFF lumens 30 min.)
Turbo (1100-650 lumens 22 min. + 650-OFF lumens 6-7 min.)
(Tested with XTAR 650mAh 16340 battery):
Turbo (950-500 lumen 21min. + 500-300 lumen 3min. + 300-OFF lumen 1min.)
ThruNite TN12 V4
Output mode/Runtime Claimed by ThruNite: (Tested with ThruNite 3400mAh 18650 battery):
Turbo (1100 lumens /95 minutes)
Output mode/Runtime - Measured: (Tested with ThruNite 3400mAh 18650 battery):
Turbo (1100-950 lumens 10min. + 850-800 lumens 35min. +  800-550 lumens 35min. +  550-OFF lumens 32 min.)
ThruNite T10 V2
Output mode/Runtime Claimed by ThruNite: (Tested with AA 2450mAh battery):
Medium (54 lumens /8 hours)
High (160 lumens /140 mins)
Output mode/Runtime - Measured: (Tested with Rechargeable NiteCore 14500 850mAh 1.2V battery):
High (550-400 lumens 20min. + 400 lumens 15min. - OFF)
Medium (400-220 lumens 50min. + 220-90 lumens 10min. - OFF)
Output mode/Runtime - Measured: (Tested with Rechargeable Panasonic eneloop pro AA 2500mAh 1.2V battery):
High (160-150 lumens 10min. + 150-110 lumens 1h:25min. +  110-Medium lumens 10min. +  Medium-Low lumens 10 min. + ...)
Re: ThruNite Turbo Mode Test
« Reply #1 on: October 16, 2020, 04:09:57 AM »
Very nice testing. I love Thrunite torches. Extremely good quality and rated pretty accurately on output. I donít think you have damaged any of your lights. The automatic step-down, whether timed or thermally regulated, is there to protect your light from harm.
I recently bought a Thrunite T2 and itís an awesome light like almost all Thrunite lights are. I highly recommend it but the proprietary 21700 cell (identical to Olight proprietary cells) can put some buyers off. I do wish they had gone with standard cells but there are longer 21700 cells that will fit but not many.
Offline Nakme
« Reply #2 on: October 20, 2020, 02:50:06 PM »
All my Flashlights are ThruNite... I love them...
This is my Collection so Far:
Ti3,  Ti3 V2,  T10 V2,  T1,  Archer 1A V3,  Neutron 2C V3,  TC15,  TC12 V2,  TN12 2014,  TN12 2016,  TN12 V4,  TH10,  TH10 V2,  TH20,  TH30,  TH01...
ThruNite T2 and TT20 are next on my list to get...
I agree with you about the customized 21700 cells... But I guess it will soon become standard, because a lot of Flashlight Models are using them...
