Author Topic: New Manker model! The MK37  (Read 225 times)
« on: December 25, 2020, 12:43:57 PM »
Manker has a new model they are releasing that I am pretty excited about.  The MK37
This light really looks like a winner to me!  Not much gets me excited these days but this sure does.
Product Description
Feature:
- Utilizes 1* LUMINUS SBT90 GEN2 LED with a max output of 5,800 lumens
- Max beam intensity of 218,556cd and max throw distance of 935 meters
- New optical grade PMMA TIR lens provides the higher quality and quantity of light in a soft and balanced beam
- Toughened ultra-clear glass lens with anti-reflective coating
- Power by 3x 18650 rechargeable li-ion batteries (Excluded)
- Working voltage: 8.7V - 12.6V
- High efficiency constant circuit provides stable output (Non-PWM)
- With advanced intelligent temperature regulation module, MK37 regulates its output and adapts to the ambient environment, maintaining optimal performance
- Electronic reverse polarity protection and over-discharge protection
- Integrated power indicator in side switch indicates remaining battery power
- User-friendly Interface, easy & fast one handed operation
- One button control all brightness levels and functions
- Lockout mode prevents accidental activation
- Five user selectable moonlight mode(0.1 - 2 lm) to meet different requirement
- Intelligent memory function stores the brightness mode & mode cycle last used
- Constructed from aircraft-grade aluminum alloy
- Premium type-III hard-anodized anti-abrasive finish
- Body oxidation color option: Black or Sand
- Premium cooling fins Design
- MK37 can be directly mounted to a tripod, turning it into a camp light or a fixed supplementary light
- Diamond-pattern knurling provide a better gripping surface
- Immersion gold and gold plated connector to ensure an effective conductivity
- Built-in lanyard hole (inner diameter: 0.138in / 3.5mm)
- Convenient tail-stand capacbility
- IPX-8 waterproof standard (2 meters under water)
- Compact & lightweight, weigh only 10.51oz / 298g
- Size: 2.0 inch /52.2mm (head diameter) x 1.85inch /47mm (body diameter) x 5.1 inch / 128.57mm length
- Accessory: Holster *1, Lanyard *1, Waterproof o-ring *1, Manual *1, 3/8" to 1/4" Tripod Thread Adapter *1
Output/runtime (LUMINUS SBT90.2)
Moonlight            0.1 lumens    70 hours
Low                     70 lumens    30 hours
Mid1                  400 lumens      9 hours 30 minutes
Mid2                1100 lumens      4 hours
High                2800 lumens      1 hours 40 minutes
Turbo              5800 lumens      1 hours 25 minutes
Strobe             5800 lumens -
Peak beam intensity: 218,556 cd
Maximum beam distance: 935 meters
Impact resistance: 1 meters
Waterproof standard: IPX-8,2M
