Author Topic: XTAR VP2, the other VP1 is coming  (Read 2871 times)
Offline Xtar Lights
« on: February 26, 2014, 01:24:01 AM »
VP2, the second charger with LCD display has been released in beginning of 2014. VP2 has several main features different from VP1.
  Firstly, VP2 could be compatible with different battery types and sizes, which could charge 22650/25500/26650 battery.
  Secondly, VP2 has the USB output, whose output voltage and current could reach 5.0V and 1.0A, which is good for supplying power for the mobile devices.
  Thirdly, different from VP1, VP2 is added the power indicator, which could not only indicate the charging status but also the battery power when USB output.
  The most important point is that VP2 not only has three charge current options and three voltage options, which could be good for different battery types, such as standard Li-ion battery, Lifeo4 battery, and other 3.0V/3.2V, 3.6V/3.7V, 3.8V Li-ion batteries.
  XTAR, as a charger manufacturer leader, has developed and produced many high-quality battery charger, VP2 will also be your best choice.
Contact with us:
sales@xtarlight.com
« Last Edit: February 26, 2014, 01:24:19 AM by Xtar Lights »
Pursue for better!
Re: XTAR VP2, the other VP1 is coming
« Reply #1 on: February 26, 2014, 06:43:03 AM »
Looks nice. If you need one tested and reviewed I'm more than happy to help you out.
