Author Topic: Defiant mod questions?  (Read 4476 times)
« on: July 17, 2014, 08:20:40 AM »
Found a Defiant in the trailer we moved to put my house in...the 3C cell XM-L super thrower
Would this driver be good enough for either 3x26650's or 3x18650's w/ adapter to run it?
http://www.lightmalls.com/super-output-ssc-p7-led-driver-board-low-high-middle-5-5v-15v-2
Or this
http://www.lightmalls.com/12-6v-3a-5-modes-led-circuit-board-for-trustfire-tr-3t6-or-other-flashlights
I kinda want to keep it 3A~ daily driver but want it to run on Li Ion instead of just plain ol' C cells
« Last Edit: July 17, 2014, 08:23:10 AM by WarHawk-AVG »
Re: Defiant mod questions?
« Reply #1 on: July 17, 2014, 09:57:27 PM »
The first one linked I have used quite a few of. Mainly with 2 lithium batteries. There seems to be two or more different ones which I have received in the same order. Differences being slow mode change (maybe half a second), different components, some whine, and different outputs any where between 2.7 and 3 amps. Overall I still use them as they are better than anything else I've tried for this price and never had one fail, touch wood, yet.
« Reply #2 on: July 18, 2014, 06:07:41 AM »
Ya know what...daggum it
C cell battery is 26.2 50, so 3 of em stacked are 150mm, 18650 stacked are 130mm...so pretty much would only need 2 18650's and not 3...duh *smacks forehead*
I was really expecting to have to put 3x18650's in there...not 2, and the nice thing...26650's x 2 and voila
herp derp
Might need a small spacer...but that shouldn't be that difficult (aka a 1" x 20mm long) wooden dowel rod, drilled down the middle, and some bolts and wire them between for electrical continuity and voila)
Ordered #1 on the list, w/ shipping $9.45, will let you know when it comes in and I mod my daughters Defiant
« Last Edit: July 18, 2014, 06:16:24 AM by WarHawk-AVG »
« Reply #3 on: July 18, 2014, 09:01:29 AM »
I have machined one tube out for 26650 batteries. They need about .65mm taken out.
