Author Topic: Wrist strap & holster  (Read 12289 times)
Offline Tecboy
« on: October 22, 2014, 08:41:00 PM »
I'm looking for a wrist strap and a holster for my HP7.  Where can I purchase these?
Re: Wrist strap & holster
« Reply #1 on: May 21, 2015, 02:00:50 PM »
Had to look up the specs on the HP7 (140mm*38mm) then I went to Fasttech to look for a holster that would fit.  The HP7 is roughly the same size as a standard P60 light so the choices for something that should fit are several.  Here are a few I found that look like they should fit:
https://www.fasttech.com/products/1630/10008506/1762902-nylon-holster-for-1-18650-led-flashlight  Very close fit based on measurements.  Good chance it might be too small around the head.
https://www.fasttech.com/products/1630/10003625/1265000-ultrafire-nylon-black-flashlight-holster-mid-size  Should fit no problem.  I have these and they fit most any mid-sized light.
https://www.fasttech.com/products/1630/10006829/1539702-jetbeam-nylon-flashlight-holster  Should be another perfect fit for your light.
As far as lanyards go if you have any paracord you can make the best lanyards very easily and inexpensively.  If you really want to buy one premade make sure it is from a quality brand.  Here are a few I found that I would consider for myself:
https://www.fasttech.com/products/1630/10009328/1825604-nitecore-ntl20-tactical-lanyard-for-led-flashlight
https://www.fasttech.com/products/1630/10009328/1825605-nitecore-ntl10-tactical-lanyard-for-led-flashlight
https://www.fasttech.com/products/1630/10003858/1275105-nylon-lanyard-strap-w-slip-buckle-21cm
Good luck and be sure to let us know how you make out. :)
« Reply #2 on: May 21, 2015, 02:02:17 PM »
I've no idea how I missed the OP when first posted 7 months ago and I never looked at the date until after posting my reply above.  If it won't help the OP I hope it will help someone else in need of the same advice. ;)
