Author Topic: Klarus XT12, Svitac Mini EDC Flashlight, Palight Battery, Pocket Torch ON SALE  (Read 2536 times)
Offline tinywind
  • I like to challenge something new.
    • Tinywind Outdoors
Klarus XT12 CREE XM-L2-U2 LED 4 Modes 930 Lumens 18650/CR123A Rechargeable Flashlight Dark Grey - $75.39 plus Free Shipping
Features:
Utilizes a CREE XM-L2-U2 LED, delivering a maximum output of 930 ANSI lumens, giving you more brightness and safe.
Patented dual tactical switch for non-visual, one-handed touch operation.
Specially designed Direct Recharging function- no need for battery removal or charger, making the XT12 more simple and light-weight.
Patented self-locating Magnetic FAST Connection charging system. When the charging cable is within 1cm of the charging port, it self-locates to make the connection. The charging cable can be removed quickly and safely at any time, which makes it an effective flashlight to use in rapid response situations.
Uses standard USB port for charging, so you can recharge at home, in the office, airport, vehicle or anywhere that has a USB charging port available.
Straight 2 Strobe function means that the strobe can be instantly accessed whether the flashlight is switched ON or OFF.
The custom KLARUS 2600mAh 3.7V rechargeable Li-ion battery uses a Samsung cell, designed to automatically align +/- polarity regardless of battery orientation in the flashlight.
Optional red/green/blue/white colour filters, suitable for various applications.
Detachable stainless steel strike bezel protects the lens and can be used for self-defence.
Tripod mountable via the standard UNC1/4′-20 threaded mounting point.
Waterproof to IPX-8 Standard (underwater to 2 metres).
Low loss, high intensity, portable USB charging cable.
Magnetic connector has built in short circuit protection which makes it safer.
USB rechargeable interface on side of flashlight with visible charging status.
Dark grey colour, military quality, sophisticated technology, durable and scratch resistant.
Deal Link: http://www.tinywind.com/-p-15286.html
Svitac Mini CREE R5 LED 100 Lumens 4.2V 1xAAA Flashlight Titanium - $7.55 plus Free Shipping
Features:
Made of high quality T6061 aircraft-grade aluminum alloy.
Using the latest CREE R5 LED, brightness up to 100 lumens.
Precision micro-textured reflector creates smooth, optimized beam.
Tailcap clicky on and off switch, convenient to use.
Waterproof design, "O" ring and gasket sealed (Not for diving, don't place it into water for a long time).
Ideal for self-safety, hunting, cycling, climbing, camping, hiking, caving and outdoor activity etc.
Deal Link: http://www.tinywind.com/-p-14262.html
6 LED Pen Light Work Light Pocket Torch with Clip Blue - $2.75 plus Free Shipping
Features:
6 Powerful LED's provide 60 Lumens of bright white light.
Portable, easy to carry and store.
Tail ON/OFF button for easy operation.
The clip provides convenient hands-free lighting.
Reinforced plastic body is shock proof and water resistant.
Powered by 3 x AAA batteries (not included).
Batteries can be replaced by twisting the bottom cap a 1/4 turn and inserting three AAA batteries, positive end first.
Deal Link: http://www.tinywind.com/-p-15190.html
Palight Li-ion 18650 3.7V 2300-2400mah Battery - $3.21 plus Free Shipping
Specifications:
Brand: PALIGHT
Type: Lithium Ion
Model: 18650
Battery Capacity: 2300-2400mah
Battery Voltage: 3.7V
Rechargeable: Yes
PCB Protected Board: No
Application: Flashlight or other devices
Deal Link: http://www.tinywind.com/-p-15278.html
--- Deals expire on May 11th 24:00 [NY Time]
Tinywind offer LED flashlights, lights parts and accessories with Free Shipping Worldwide, No Minimum Order Required.
