Author Topic: Review. Fasttech 1-4.2 volt single mode driver.  (Read 6411 times)
« on: August 07, 2013, 10:18:21 PM »
Mode
Battery Current Draw Amps
LED Amps
LED Voltage
Sanyo 18650 at 4 volts
High
1.75
1.45
3.05
Ultracell LiFEPo4 at 3.5 volts
High
1.27
.91
2.94
Eneloop LSD AA at 1.4 volts
High
1.7
.23
2.74
This driver was purchased from Fasttech. Link below.
https://www.fasttech.com/products/1143101
Specifications from Fasttech website.
PERIPHERAL TYPE             Flashlight Driver
Electronic Components
CONSTANT CURRENT     No
DRIVER TYPE      Boost driver
INPUT VOLTAGE               1-4.2 -volt
OUTPUT CURRENT          1000 mA
PCB HEIGHT (W/O COMPONENTS)           1.8 mm
REVERSE POLARITY PROTECTION              No
Flashlights
MODE COUNT   1
Package
PACKAGE TYPE  OEM
Dimensions us | metric
DEPTH   8 mm
HEIGHT 17 mm
WIDTH  170 mm
DIAMETER           17 mm
PRODUCT WEIGHT          2.0 g
Product Numbers
FASTTECH SKU  1143101
Details:
Manufacturer rated maximum currents:
With alkaline batteries: 1000mA
With 1*Ni-MH: 1.8A
With 2*Ni-MH: 3.9A
Again the Holy Grail off multi voltage capable drivers continues. This driver is single mode only and is fortunately not inflicted with the dreaded next mode memory. The driver does indeed operate over the advertised voltage range. Tested output on 3.5 to 4 volts was surprisingly good with led current draw off .91 to 1.45 amps. I’m not sure on the efficiency off the driver. l’ll leave that for the experts. The disappointment was the output on a single AA NiMH. Three different batteries were tried with the testing on each battery performed three times as I expected the output to be higher at the led. The AA batteries used, all fully charged, were a brand new Eneloop, Turnigy LSD and an old Powercell from Jaycar. The Eneloop gave very slightly higher readings.
An XM-L LED was used for this testing.
Offline Samhasing
Re: Review. Fasttech 1-4.2 volt single mode driver.
« Reply #1 on: February 27, 2018, 07:09:59 AM »
I have read it, it's wonderful, and it's a must to follow.
Offline ShadowKhan
« Reply #2 on: May 25, 2018, 06:22:17 AM »
It is very good content to find information for me.
