Author Topic: Pocket-Sized P60/Mag D hybrid - BEAMSHOTS AND LUX NUMBERS  (Read 3159 times)
Offline Chicago X
« on: August 08, 2013, 11:10:01 PM »
Who says that a Mag D can't be pocket-friendly?
Here's the breakdown:
The magic starts here:
Threading the inside:
Finished part:
It looks good with a 2 x 18650 body too:
I think this is the funniest light I've ever made:
The biggest PITA is the threading; the Mag is a standard 20 TPI thread, but the P60 is a metric 1.25 mm pitch.  While very close, they are not the same and require a gear change on the lathe to cut metric threads.
Here's the solid copper pill:
Driver pocket:
Here's the side view.  The groove is for aerodynamics.
Actually, I started the cut in the wrong place, and didn't want to waste the part.  Tongue Out
Here's the slug, nestled in the Solarforce body:
Copper-on-copper?  Yes, please !
Here's the business end:
Beamshots and lux/lumen measurements to follow.
I took a couple of beamshots of several torches tonight, including this light.  It measured 44000 lux@1m with a single IMR RCR123, running at 2.8 amps.
The 5000K XM-L2 is a very pleasant neutral-white, and not green at all.  The white balance on my camera shifted the color a bit.
This was only the second light I've built that made Mrs. X say "wow!"
Offline [MOD-BOT]
  • Master Flashaholic
    • Worldwide Flashlight Forum
Re: Pocket-Sized P60/Mag D hybrid - BEAMSHOTS AND LUX NUMBERS
« Reply #1 on: August 09, 2013, 07:25:39 AM »
That must've been fun!
I wish maglite would incorporate Li-On batteries for their torches, because to be honest, a single 14500 torch running almost any LED at 100 lumens for twice as long as a 4D mag will power their incan for the same output or at least the same time as it will running an LED.
I mean, mag has always been to go-to torch for contractors, plumbers, repairmen, and even some old fashioned cops.
If only mag would make a higher quality host and a smaller size with more output and ability to use Li-On's, I will have to stop purchasing their torches.
Your Forum Guard
